L Thread Starter Lecko Mar 5, 2002 #1 I am after Pinout info for a 1784-CP14 cable. It is to connect a a KTX card to SLC503. Can't find info in online manuals. Can any one help.
M Mark Mazzeo Mar 6, 2002 #2 Try this link to the online manuals: http://www.ab.com/manuals/open/1747...pe=xml&Collection=English&QueryZip=1784-cp14&[/URL]
L Larry Lawver Mar 6, 2002 #3 Lecko--- The URL link is below, but in case it doesn't survive processing, your information is in Knowledgebase Article G16833 at "http://support.rockwellautomation.com/":http://support.rockwellautomation.com/ "http://domino.automation.rockwell.c...4FA7CA591F37ADD185256AFB006501F4?OpenDocument":http://domino.automation.rockwell.c...4FA7CA591F37ADD185256AFB006501F4?OpenDocument Hope this helps! Larry Lawver Rexel / Central Florida
S Stephen Apr 30, 2002 #4 <P>I have looked at the document on the knowledge base. but I still dont know how to connect the resistors.</P> <P>I am connecting my 1784-ktx directly to slc5/03 </P> <P>Do i put a 150 ohm at both ends ? & betwean which terminals</P> <P>Is the RJ 45 conection numbers from the top down ?</P> <P>My connection is as follows</P> <PRE> 6 pin phoenix on 1784-ktx slc5/03 RJ 45 8 pin 1 chassis gnd ( also screen) 7 2 shield 6 4 DH485 A 1 5 DH 485 B 2 </PRE> <P>Is this connect </P> <P>Thanks a lot </P>
