We often get questions like this posted to the forum. It would help if you explained what it is that you need to know. Your question takes in a broad area.
Can anyone point this gentleman to a good general reference to get him started?
First you need define which of dozens of AB models of PLC you are using. Some require external add-on products/slot-cards. A FEW support Modbus directly (some of the higher-end MicroLogix).
If the Allen Bradley PLC is the master without any serial ports available, then they make the 1769-SM2 card which can also be used as a Modbus RTU Master over RS485, see link below for manual.
This card can be used on a Micrologix 1500, Compact Logix and Control Logix PLCs. These are cheaper than the Prosoft cards, but the trade off is that the setup of card is a little bit more involved than the Prosoft cards...
We have a controllogix plc and need to communicate with a DCS that uses controlnet for I/O communications. do i need to connect the prosoft Modbus to the controlnet to receive data from the DCS or i can just use a controlnet module for the controllogix to receive data from the DCS?
Thanks for your kind replies. Sorry for the newbie question, because i am just new in AB programming and DCS communication.
<b>Moderator's note:</b> the forum software places spaces in long urls. Please delete them when copying and pasting them in your browser.
But above documents only details setup, configuration and programming on Controllogix side only. In order to get Controllogix and third party communicate through Controlnet, you need to consult also with DCS manual. Please check which method (message/produce-condume) your DCS supported
