Has anyone produced a Concept DFB or has produced function block style code to replicate the functionality an Analog Transfer block (Bailey FC 9). This function block selects one of two inputs depending on a boolean input which is then transferred to the output (same as the SEL block in Concept). However the Bailey FC also has two configurable specs which are time constants to provide smooth transfer in both directions. When the transfer block changes the input selected, the output changes to the new level exponentially over a period of five time constants when the transfer time constant specs are set to a value other than zero. After five time constants, the output tracks the selected input.
