Does anyone have experience with connecting the Aromat FP0 series PLC to a modem and setting it up to initiate outgoing calls to transfer data to a host as well as receive incoming calls?
Don't have any specific experience with the Aromat PLC but our DIN rail mounted Dial up modem should be able to do what you need. It is DC powered, and will dial out based on a contact closure from the PLC. It will also auto answer when called. You can see a data sheet at "http://www.miille.com/din366-100.pdf":http://www.miille.com/din366-100.pdf
