I have set up an As-i Bus Network through a PLC As-i master module. This network contains the PLC,the As-i master,the As-i power supply and some slaves,ones with seperate 4I and seperate slaves with 4O.
Although the network does not have any problems, there is something that i am missing. At the manual of one of the Output
slaves (Code number XZS DA04D32) says that i have to supply external supply to the actuators so i can have the output signal,and this must be done through the Slave's base. And this is the problem, i don't know the exact way to give this seperate supply! If anyone can help me please i need it.
Thanx everyone in advance
