At Cold Startup Why ST load>GT load
Dear All,
We often see, At Cold Startup Steam Turbine load(MW) (e.g: 55.4MW) Higher Than Gas Turbine Power load(MW) (e.g: 48.5MW).
I used to believe that Gas turbine is the main source of power, It's generating load always higher than Steam turbine load no matter what(misconception!!)
1. I want to know how ST load>GT load (at cold startup) *also in normal condition*
2. What about Gas turbine fuel control and ST Main Steam Control valve inrespect to ST load >GT load.
Appreciating for giving your valuable time.
Thank You
Dear All,
Thank You
Hi all,
Abby,
Here some notes which can answer to your questions
1.According to start up curves ( Conventionnal or fast start ) , the GT load is holded for ST temp matching ...
Thats what i remenber ...
2.Also there should be more precisions on that GT /ST load Controls philosophy on the OEM startups curves documents that you may got....
Now if you can share your site "startup/shutdown " curves we will be able to advise you better...
James
