We currently have access to a 4-20ma signal being used for data logging from a gas pressure transducer. The gas pressure to the burner varies from 8"H20 to a high of 13.5 at full fire. The roast master prefers to manually control the firing rate himself throughout the roast. He would prefer to not have to change the speed of the combustion air mixture dc blower every time a change is made in firing rate. Using the 4-20ma loop as an input, what would be the best way to have the fan track the burner gas pressure producing a variable dc output to the 12 volt dc blower? DC voltage at it's slowest speed is 5 volts, highest speed is at 10 volts. The fan draws 4 amps at 10 volts. Coffeeal
