I am having problems communicating with an Automation Direct PLC using VHMI drivers. Can anyone help?? It is a simple app of sending and receiving data. Thanks.
What is a vmhi driver? I use ethernet to communicate with a DS 250, and IPX has to be installed, and IP has to be set to match the PLC. Automation Direct has a utility called NetEdit that helps in establishing communications also. Rob
