We had an HMI upgrade on Frame 7EAs in December and since that time receive SOEs for low lube pressure 63QA-1 and low lube pressure-trip load63QT2A/B on one unit. The problem is it appears to be demanding a start of Aux Lube Pump and as soon as pump starts those 3 bits' logic returns to a "0" logic but the pump continues to run for approx. an hour. Yesterday I saw the logic states had changed on the event logger and in checking discovered the immersion heaters were not on. With the unit at zero speed this should not initiate the aux lube pump and not receiving alarms only seq of event. All units received upgrade at same time and this is occurring on only one. If anyone has encountered this previously or can point me in the right direction will be greatly appreciated.
