Situation: encountering installation obstruction for pitot tube flow sensor for measuring liquid (water). the pipe is just barely above ground with no allowance to install the flowmeter at bottom half of the pipe, as per manufacturer guidelines for liquid.
Ques: what are the affects on flow measurements if fluid is approx fully filled and that we install from top at 12 o'clock or 45 deg from 12 o'clock - such as following measuring gas application ? has anyone install it, such way ?
Thanks.
Thanks.
