Barcode Scanner direct to Quickpanel display
Duncan Thomson
I have been told that a barcode scanner can be directly connected to a Quickpanel (Proface) touchscreen. Does anyone have experience with this? How does one retrieve the barcode via the serial port? Do you use the ascii protocol, if so how does this work without header characters? Or is there some D-Script function which covers this? If I can get it working I will make the results available... thanks Duncan
artb-bcs/swt
About 3 years ago I used a bar code scanner with a decoder and keyboard wedge. Perhaps you might find what you are looking for from these people: NJCR, 1-800-366-6535 Regards, Art Bourdeau Web: www.bcsco.com Phone: 518-765-3667 Fax: 518-765-4033 Mobil: 518-573-4745
