R
When does the machine changes over from Preselect Load to Base Load??
Our Machine was set at 20MW Preselect Load... The machine came to Temp Control at around 19.2MW... The Status_Fld1 display was switching over between Preselect and Base mode regularly....
What factor will switch the machine from Base to Preselect Load and vice versa..??
What factor should keep the machine in Base Load/Preselect Load constantly...??
I thought, once the machine is on Temp Control Mode, it wud be always in base load... Is it not right??
Ours is a 20MW Frame V machine, MARK V controls, <I> Station display...
au revoir
Rahul
au revoir
Rahul
