I am trying to determine the best valve configuration to control boiler feedwater. Should I use a normally open or closed valve? This is for an industrial water tube boiler that is not continuously manned. It has a 3 element feedwater system. We are currently replacing the valves and need to determine the pros and cons of each. I have received conflicting information from the boiler manufacturer, valve manufacturer, boiler control vendor.
