H
I have a project ware I have to make a communication between ethway and mapway. The existing plant PLC communication is via mapway (Existing PLC TSX 6740), then I will upgrade the monitoring system by Monitor pro 7 where the communication via Ethway.
When I read at Manual this problem can be solved by bridge PLC. At this case, I have question:
I must place a special base plate with new PLC, new Mapway Card and new Ethway Card
or
By place the new Ethway Card at Existing Base Plate.
I need a detailed procedure for this job.
Best regards.
or
Best regards.
