We are currently working on a project where we have to communicate with 3 x Inverters (in parallel mode) and the requirement is to send a Broadcast message to all inverters and perform the function in all inverters at the same time, For example, we would like to set the Operating Mode of all inverters to Auto by sending one message. Modbus broadcast address is 0 as we understand and the problem is that the broadcast message is not performing in this configuration. We are able to set the Mode in each inverter by addressing them directly, with the current wiring in place. Appreciate if someone could advice as to whether there is a different message format for broadcast messages, that is different to Query message that is sent to each Inverter?
