I am designing a hybrid vehicle drive system, which needs to use a brushless DC motor/generator (generator to charge battery, battery to apply electricity to motor).
The hybrid drive train consists of a fixed axle, which is connected by sprocket gears to the motor/generator, the axle is hand turned to demonstrate internal combustion engine torque (which is used to spin the unit as a generator).
________________________________________________
However, I am not sure on how to switch between operation as a generator and as a motor...this may be very simple but I am getting confused.
My thoughts are, when the battery is connected by a single path to the motor/generator, the battery will drive the unit as a motor, regardless of the torque applied to the axle by hand turning, therefore not working as a generator and charging the battery?
So my question is, how can I switch between the operations? and is this achievable?
Thank you in advance.
