R
We use bubbler systems to measure level in our scrubber's slurry tanks. Slurry is composed mostly of limestone and sulphate from a flue gas desulphurization process. Our problem is the constant plugging of the dip tubes; we have tried different combinations of air flows and pipe diameters but still need to clean the tubes every 3 or 4 days, or even more often in some cases.
Is there a guideline for selecting proper tube diameters and air flowrates to minimize plugging?
As additional info, plugging sometimes takes the form of a solid crust or ring of solidified slurry a few inches above the end of the dip tube, as if the bubbles dried up and plugged the tube. In other cases it is simply a semi-wet mass of slurry that plugs the tube but washes out easily; this could be due to a momentary pressure loss allowing slurry to get into the tube, but we have worked to eliminate pressure outages and personnel has been trained to never shut down air, so I would believe it has more to do with improper airflow.
Any suggestions or comments will be appreciated.
