Cable tray separation
jasoin carroll
do you know of any standard that says the highest voltage cable should go in the top or the bottom tray?
I have found api 552 to say the highest voltage should go in the BOTTOM tray. this is contrary to everything i have ever seen. any thoughts??
thanks!
Jasoin... I suggest you procure:
ANSI/IEEE Std 422-1986
"Guide for the Design and Installation of Cable Systems in Power Generating Plants"
Phil Corso
Jasoin... The ANSI/IEEE-Std supports your contention regarding Vertical Segregation of Data "Transmission" cables and power cables.
The conflict arises because the API-std fails to prescribe what is represented by "Hi-Voltage!" construction.
Phil
