Calculating Natural Gas Flow
G
G. Woolley
Have an existing 3095mv transmitter mounted on a Accelabar from Versis and would like to use the flow calc in the transmitter and not in the DCS.
3095mv seems to only allow selection of their own annubar for the sensing element, has anyone actually made this work?
Glenn
Glenn,
I suppose you got the software Engineering Assistant, when you do a flow setup, you can select type of primary - select "Other", then "Area Averaging Meter" and a value for "Constant K".
Download to 3095 and check with "test calc".
If not correct you can probably correct changing "Constant".
