I am working on 3D printing construction and my objective is to control the flow of the material so for that I need to control the motor. I am using Nord motor Asynchronous motor 100LA/4, and I am trying to calculate the different parameters of the motor like resistance inductance capacitance and motor constant. I have tried different equations to calculate but the simulation result is not good with those values so could you help me that how can I find the good values for these parameters?
Full load power = 5hp, 3.7kw.
full load speed = 1725 1/min
Mn = 20.5 NM
IN = 230v, 15.2 amp
rotor inertia = 0.006kg.m2
I will be grateful if you could help me. Thanks and awaiting for your response.
Dipen Patel
Mn = 20.5 NM
IN = 230v, 15.2 amp
Dipen Patel
