I
Hi all,
Is it necessary that an Instrument have accuracy mentioned in its specs? Can linearity act as a substitute to explain the accuracy of an instrument?
Suppose, I have an instrument. I calibrate it using a standard reference between Zero and Span. Now if the instrument has a linearity of 0.1% then for all intermediate values, the readings are likely to be within 0.1% of the line joining Zero and Span. Isnt it, then, enuf to NOT worry about the accuracy? How will the information about accuracy be any different from Linearity, in such a case.
I am sorry to ask such a basic question but I am stuck up with an instrument where I have to know its accuracy. The spec sheet mentions everything BUT the accuracy. It talks about Zero drifts, span drifts, minimum detectable limits, noise, linearity etc.. But not accuracy. So I am trying to understand, if accuracy is at all required to be known for an instrument OR linearity information should suffice.
