N
There is a requirement to transmit 460 Hertz, 6000V ac supply over a distance of 7 km by a cable. So the output of the frequency convertor which is 460 Hz, 360 V is connected to a step up transformer is subsequntly connected to the high voltage cable of 6000 meters length. When the tail is open circuited, the cable draws a capacitive current of around 10 Amperes at 6000 Volts. Due to this the temperature of the frequency convertor is very sharp and trips due to overtemperature within a few minutes. It seems switching capacitive load is the main problem. Can any one suggest how to overcome the problem?
Kind regards,
N.Vedachalam,
India.
Kind regards,
N.Vedachalam,
India.
