P
We made the link work by plugging a cross-over patch cable into the existing wall plate which is connected to the server by a straight connection to the main hub. The RJ45 at the other end of the patch cable was then plugged into the loose wall plate of the link being tested.
The link consists of a loose wall plate, about 100 feet of CAT 5 to an RJ45.
The RJ45 end of the link was plugged into a switch which was in turn connected to the computer by a cross-over cable. We were able to connect to the internet and therefore thought that the link was OK.
Unfortunately this was not the configuration we required and when using the same link to connect from a hub or switch, and then via a cross-over connection to a computer, it could not be made to work.
This particular installatio was done as a favour for a friend and has been a complete learning experience. We have never had so many problems in the past and would now advise anybody not to invest in anything related to copper.
Would be most grateful for any advice.
