Challenge! How long (seconds) will it take for the actuator to travel to from zero to full stroke (184.15 mm)?
We have an Actuator with an area of 36 in² (Camflex 7 actuator).
Stroke length = 7.25 in (184.15 mm)
Spring range = 7 -24 psi
We supply 6 bar air to the actuator through an orifice with a 1 mm dia hole.
Hi Fanie V wyk
I found this video explaining how to calculate speed and so on time on actuator operations :
Tell us if it can be used in this case?
Controlsguy25
Hi Fanie V wyk
Controlsguy25
Fanie V wyk,
It would be fine to tell us how things are going on this thread subject??
As we spent time trying to support/help, you and then we can ask for miminum feedback to close the thread.
Thank you for your understanding,
Controlsguy25
