P
We are using a VFD for our fan control application . We are presently using Abb make samistar drive in our fume extraction system. The drive is used for driving an induction motor of the capacity 1200kw . The motor is of 660 V rating and vvvf is used to soft start it and then raise it to a frequency of 40 Hz.
Though the application doesnt need a variable frequency drive it is used more as asoft starter.
We are facing lot of problems with this drive like frequent blowing off of GTO's and the card failures . So we are thinking of a option of converting this sytem to a dol starter type.
We are thinking in terms of the following changeover scheme.
The motor is for fan application the strating current required will be very high so we will give it a soft start using The VVVF drive. Then we will raise the frequency up to 50 Hz and will run the fan till it achieves its full speed.
Once the full speed is achieved we will switch off the VVVF drive and start the DOL breaker.( the breaker will be of 3000 A 1000 V rating with all the features of a normal Breaker.)
This breker will start as soon as the VVVf drive is switched off and the outgoing breaker is switched off.
Problems
What all problems are anticipated in this change over scheme ?
Please post your comments.
I will be very thankfull to all those who will respond.
Parish
Problems
Parish
