Only if you want every technician to swear at you when he can't find the other end of the wire. The way to do it if you really have to is to go through a pair of terminal blocks side by side and put a jumper between them and then mark the drawing accordingly.
I have been using a system that works extremely well even if you change the drive name and Number
Example:
Electrical Cable Number = Q00001/001/002/003etc put on both ends of the wire.This wire number will never change even if you change
the equipment number Very few changes will be required for the new drawing to be updated
Instrument wire number could be I00001/001/002/003etc. Any letter will do as long as it follows a set pattern Try it on an example [email protected]
