Cheap Modbus TCP module similar to STRIDE Field I/O?
I've been using STRIDE Field I/O modules from AutomationDirect but they seem to have become unobtanium.
https://www.automationdirect.com/ad...d_i-z-o/stride_i-z-o/analog_i-z-o/sio-mb04ads
The features that I like about them is they are cheap, they can be configured over ethernet in a web UI, there are modules that can handle 4-20mA or 0-10V analog in, and also modules that can read thermocouples, then translate directly to modbus TCP.
Does anyone out there have a similar sort of module they like to use that is not really expensive?
The closest I've seen to SRIDE Field I/O is this:
https://www.datexel.com/0-10v-to-ethernet-dat8017-v.html
The only annoying part looks like you have to configure it over serial, so no web UI.
I did have those on my list to evaluate. The other thing I was looking at is the hardware from brainboxes.
I feel like all of this hardware is more complicated and more expensive than it needs to be though.
