Cimplicity help
1700873866322.pngGreetings, I'm needing a little help with cimplicity.
The problem occurs when the alarm screen is inactive for 5 minutes, an error appears in Windows indicating that the PROCALM2 service has detected a problem and must be closed. When I open the procalm2.txt file I see that when the error occurs, the following is recorded:
procalm is idle. closing connection with AM.
As long as I keep acknowledging, blocking, resetting alarms or doing something on the alarm screen it doesn't give the error. The problem occurs when 5 minutes pass without executing commands.
Does anyone know of a configuration in cimplicity where I can eliminate that timer to enter idle?
It is a ge5001 unit with mark V and cimplicity veesion 9.0 running on windows 7.
Thank you in advance for any help.
Ícono de validado por la comunidad
