I run this code in cicode function -<pre>
FUNCTION SQLTest2
INT hSQL, iResult;
STRING sName;
hSQL = SQLConnect("DSN=citectmssqlh;DB=Histy;");
IF hSQL <> -1 THEN
iResult = SQLExec(hSQL, "select top 1 CONVERT(nvarchar(4000),SampleValue) as SampleValue from dbo.AllSamples where TagID='443' order by SampleDateTime desc");
IF iResult = 0 THEN
sName = SQLGetField( hSQL, "SampleValue" );
RETURN sName;
END
SQLDisconnect(hSQL);
ELSE
Message("SQL Error", SQLErrMsg, 48);
END
END </pre>
When i add it in graphic builder under text properties and compile it i get 'incompatible types' error
Please help
FUNCTION SQLTest2
INT hSQL, iResult;
STRING sName;
IF hSQL <> -1 THEN
IF iResult = 0 THEN
RETURN sName;
END
ELSE
END
END </pre>
Please help
