I want to read data with CITECT from a IP Master (ISYGLT) with a MODBUS!!
The problem is that the IP Master does not respond.
Does somebody know what I do wrong??
The I/O server, Boards, Ports, I/O devices and variable tags are made
Server
Servername = IOServer
Board
BoardName = TCPIPx
Boardtype = TCPIP
board adres = 0
The other fields are blank
Port
Port name = TCPIP1
BoardName called = TCPIPx
Specila opt. = -I192.168.0.225 -P0 -T
I/O device
IOdevice name = ISYGLT
Protocol = MODNET
Portname called = TCPIP1
The other fields are blank.
Variable tags
Variable tags name = MODBUS_40001
Data type = int
Adress = 40001
IP-Master
Protocol (MOBUS/TCP(P502) and Port 502
connection = 4.MODBUS Holding Register (Byte/Word)von MODBUS lesbar- und schreibbar
MODBUS Holding Register (Byte/Word)  von MODBUS lesbar- und schreibbar
Nur Bytes und Words
MODBUS Start-Register: 1
MODBUS Länge (Anzahl Bytes): 4
MODBUS Länge (Anzahl Words): 4
ISYGLT Merker-Bank : NA
ISYGLT Start-Merkernummer: 1
MODBUS is working with Programmer designer and ModScan32.
Kind regards,
Server
Board
BoardName = TCPIPx
Boardtype = TCPIP
board adres = 0
Port
Port name = TCPIP1
I/O device
Protocol = MODNET
Variable tags
Data type = int
Adress = 40001
IP-Master
Nur Bytes und Words
Kind regards,
