K
We are having 6 nos of Gas Turbine (GE supplied Frame 9E m/c, model no -PG9171E) controlling through Mark vi technology. All the m/c normally running on Natural Gas.
The gas fuel vent valve close feedback (L33ps1c) was lost and a sudden loss of pressure in the gas supply line occurred. This led to a change over to liquid fuel. The changeover was initiated due to a loss of FPG1 (l96fgl SRV inlet gas fuel pressure low).
The changeover signal L43FL_PRSET got picked up since the opening of SRV reached >95% for maintaining the downstream pressure FPG2. However during changeover to liquid the liquid fuel pressure also went below 10 psi which caused the signal L43FG_PRSET to pick up and the machine came back to total gas fuel despite having a low gas inlet pressure. And after 120 sec the signal L43FL_T got picked up which tripped the GT.
Want to know how gas vent valve close feedback loss will reduce gas supply pressure as there is neither any SOE or alarm observed of Gas vent valve open nor any open limit switch of gas vent valve found.
