L
I am new to the PID & I would like to take suggestion in the implementation
My temperature range: 0----250 So Set Value will be in this range given from HMI.
Module resolution is from 0----0FA0 ( which is equivalent to 0----10v)
Generally I planned to implement like this without using PID instruction
If Suppose SV=250
PV=100
difference=SV-PV=+150
This Maximum difference will be 250
for 250 Centigrade-------0FA0 (10V output)
So 150.. -------= (150 *10)/250 =6V (interms of volts)
Gas valve will open proportionately 0--10v.
Can I use SCL instruction for this manipulation?
The above calucation will be going on as long as difference carries positive sign.
If it is Negative sign, immediately we will stop/close (0 Volts output) the Gas valve & will continue till reaches Zero.
It is the general idea but i don't know what kind of problems i will face with this?
Also I would like to know what are the advantages of PID over above?
I really looking for the earliest possible reply
Thanks in Advance
Lakshmi
If Suppose SV=250
PV=100
Thanks in Advance
Lakshmi
