P
Is there anyone who helps me understand what combustor shell pressure is in a gas turbine? Is it simply the pressure of combustor inside when commbustion is made? Thank you in advance.
N | Effect of High Modified Wobbe Index on GE frame 9E Combustor Dynamics | Power Generation | 1 | |
D | Difference Between Standard Combustor and DLN Combustion | Power Generation | 1 | |
H | purge valve caused combustor burning | Power Generation | 3 | |
A | staged dray low nox combustor | Power Generation | 0 | |
C | Combustor Bypass Valve | Power Generation | 0 |
