Hello;
From ABB's documentation, the Advant controller 110 has a built-in Profibus-DP master. The S7 controllers (those that have built-in Profibus-DP) can be set-up as Profibus slaves. Just import the S7 gsd file to the AC110 master configuration, insert a S7 slave in the Profibus configuration, properly setup and address the S7 (in Step7 HWCionfig) both for Profibus and I/O areas, connect with Profibus cable and serve with a twist over ice...
