Communication S7-400/WinCC
G
Guilherme
I have to communicate a S7-400 ( with CP 443-1 ) and a WinCC Station into a Industrial Ethernet ISO protocol. What is necessary to do into the PLC program? Is there FBs for that? Please, I aprecciate any hint about it because it is my first time in Siemens PLCs.
Standard Library
-> System Function Blocks
SFB 12 - BSEND
SFB 13 - BRECV
OR
SFB 14 - GET
SFB 15 - PUT
Depending on whether you want the slave to be active or passive.
Highlight block and press F1 for help/example
Hi Guilherme,
visit
http://www4.ad.siemens.de/news/cs/en/6159111
first. For further information visit also the section "manuals" at
Automation Systems > SIMATIC HMI products/systems > Process visualization > SIMATIC WinCC system software > Communication / channels
for free download simatic original manuals!
regards guenther
Shahid Waqas Chaudhry
You can use the S7 protocol on the Industrial Ethernet. That way you would not have to *anything*. Just define tags from differnt memory area (ie I, Q, M, DB etc).
Otherwise, you can use the SEND/RECEIVE blocks. The detailed information about this could be found from the NCM manuals (IE).
Hope this helps.
Shahid
