N
Dear Experts,
I have notice in "GE Gas Turbine Performance Characteristics, GER-3567H" manual that "COMPRESSOR AIR EXTRACTION IMPROVES HEAT RATE BUT DEGRADE GT OUTPUT". As for air extraction, mass flow of air will reduce that's why GT output may reduce, but how HEAT RATE will be improved of GT? I want to know the basic things. I am describing here about our compressor air extraction points:
1. 9th and 13th stage air extraction for 2nd and 3rd stage nozzle cooling (Also Ejector system).
2. 16-17th stage internal air extraction for bucket cooling.
3. Inlet air processing unit for inlet filter pulsation from CDC.
4. IBH (during lower load).
So how these all extraction will improve GT HEAT RATE?
Thanx in advance..
Thanx in advance..
