R
Hi there,
Our plant is using GE Frame MS 9001 GT. Right now, GT1 compressor bleed valve #4 (VA2-4) is always giving us problem. Due to the nature of the plant which is baseload, occasionally at night especially when demand is low, we will shut down 1 GT. VA2-4 getting stucked close always happen. We have checked the solenoid valve. The last time when it happened, we were wondering if the spring tension wasn't great enough to get the spring to push the valve into open position which is the venting position.
A modification proposal is done to install a permanent compressed air line so that the operators can do stroking. Right now, the immediate solution when the compressor bleed valve is stucked close, it is stroked a few times and it will work. Any1 has any ideas on how to deal with the problem?
