R
Hi there,
we are running on GT Frame 9E. Recently, the CPD dipped by 0.4 bars (usually at 10.3 bars when on base load) when we went from minimum to maximum. We were struggling to get the load we wanted. The most we could generate was 100 MW. AA pressure was at 12.5 bars. When we inspected the GT, these were what we inspected:
1. IGV opening (required and actual position, servocurrent and LVDT)
2. Air filter house (DP at 1.4 inches H2O)
3. Compressor bleed valves (no alarm was annunciated) Local indication shown close for two bottom compressor bleed valves based on position of lever.
4. Any unusual compressor turbine leakage and i.e
When we inspected the turbine compartment for leakage, we noticed the increase in temperature. The heat was really intense although turbine compartment temperature from HMI showed only 51C. We used a rod and tied a cloth at the end of the rod and pointed it around in the turbine compartment for any unsuspecting leakage. Subsequently, we found FA 6-1 which is the porostone filter to solenoid vlv for compressor bleed valve 20 CB-1 air leaking from it.
That night, that GT was shut down and gasket was changed. This morning when we started up, GT CPD was back to normal at 10.3 bars. Load was up to 108 MW. Can the leakage of the porostone filter FA 6-1 really cause the CPD to dip? Previously we had leakage from FA 3-1 and FA 4-1. There was loud hissing noise which was obvious due to their location outside the turbine compartment beneath the grating. Appreciate your feedback.
