PS/2 is not an rs-232 based communication. If you have a USB port, you may
have a slim chance of getting it to work. Best bet is to go buy a notebook
with "real" ports on it.
yes, the serial com only got 3 point, TX, RX, GND pin2,3,5, 2 and 3 are swapped, 5 going to seven,
the rest segnal should common,
or easy way is to use break out box
REMSYS
Yes, Rufus, believe it or not, many laptop manufacturers feel that we no longer need a serial port. I guess they think that a USB port is all that's needed? I hope that keyboards remain for a while! ;oP
As for Juan's dilemma... I have had good results using a PCMCIA serial card to add a second COM port to my Toshiba. The one I use is made by Socket Communication:
Your best bet is a USB to serial convertor, but that does require that your notebook has a USB port, your software can access serial ports with
higher-than-usual-numbers.
Absolutely it is possible to buy a laptop without a serial port - the cheaper Compaqs don't have one! We had to buy a PCMCIA serial port adapter to use our PLC software when someone bought us a laptop without checking the specs well enough.
