V
I am running PLC software called concept from schneider electric in a virtual machine. As the software is not compatible with the newer OS (I'm using Windows 7), I installed the software in virtual machine (vmWare) to do programming.
However, every time I try to convert file located in the host directory (via shared folder) using Concept Converter, there's always a GPF error appeared. Following is the message :
OS errno : -914
error reading from a data or key file
OS errno = 2
DLL : RDM 330
followed by :
DBConv caused a General Protection Fault in Module RDM330.DLL at 0026:112F
This problem keeps happening for conversion of a project with big size (>650MB). This problem does not appear with smaller size project or this project is located at the virtual hard disk.
Does anyone face the same problem? hope someone can help me. Thanks!
virtualguy
OS errno : -914
OS errno = 2
DLL : RDM 330
followed by :
virtualguy
