conffile, smm, puffinplc and libraries (was: Modbus/tcp works on the lplc repository)
Jiri Baum
Mario de Sousa wrote:
> What with all the XML debate going on, I was thinking of creating an
> intermediate API to access the plc config file.
> I would like to sugest we keep the existing functions and semantics, but
> change the names of these functions to something like
> plc_conf_get_value(...) , etc...
I think we should wait until we have a bit more experience using the API, then we can design a new one, maybe with different semantics, and have the conffile_*() functions only for backward-compatibility (and gradually retire them).
Changing just the names doesn't seem worth the effort...
Jiri Baum:
> > > > Actually, there needs to be a generic way of starting up a
> > > > linuxPLC, because there'll always be a collection of processes to
> > > > be run, plus setup and shutdown. It shouldn't be a perl script but
> > > > rather a C program that runs according to a section in
> > > > linuxplc.conf
> I've been thinking for quite some time of adding this piece of code to
> the smm-mgr but other stough has been coming in the way. The -g command
> line option would first init the common shared memory resources, and then
> launch modules configured in the config file.
I'm not sure if it really belongs in the smm-mgr; I'd have probably made it a separate program, in another directory, that works init(8)-style. Maybe
that's just the small-pieces philosophy...
It may be useful to be able to do the startup and shutdown manually, running the pieces separately.
I would prefer it to be separate. It'll be a big enough program without also handling the SMM setup/takedown, and the two functionalities are not really all that related.
> BTW, I sugest we change the name of the smm-mgr to plc-mgr. What does
> everybody think?
If it handles the startup, then yes, it should be plc-mgr or puffinplc (just change name of the binary, though). If the startup-shutdown process
is separate, then smm-mgr keeps its name and the startup-shutdown process gets the name puffinplc.
I think it should be called "puffinplc", because it'll be the program most people will run to start the LPLC.
> Another sugestion, seeing there are more people producing code now, is
> that we move the utility function files (sin_util.c, sem_util.c, ...) to
> a common directory, so other modules may use them if required.
Yes. I'm not sure if all of them are really clean enough to be generally offered, but certainly there should be a directory for miscellaneous libs.
Maybe even the conffile and logging libraries should be there.
> They can also be used from the smm directory, but I would like to keep
> the public interface to the smm directlory limited to the plc.h file.
If we move the conffile and logging libraries out, then it'll really be the smm.h file that's the public interface to the smm directory - and the libs directory will acquire a mini "plc" library that just has plc_init(), plc_done() and keeps track of the module name.
Maybe I'll do that sometime...
Jiri
Jiri Baum <[email protected]>
What we do Every Night! Take Over the World!
LinuxPLC mailing list
Mario J. R. de Sousa
> retire them).
OK. We have enough to do at the moment...
> Jiri Baum:
> > > > > linuxplc.conf
Then why not use the init itself? Why must we re-write a similar program?
Do you mean different modules when you say pieces? In that case you can. Start them up as we are already doing right now; from the command line.
If you mean start up all the modules independently of seting up the plc resources, then you have a point. We might give it another command line option instead of -g.
I think they are related. Each is a step in the two step process of starting up the plc.
But let's not quible over a detail. It is very simple to cut the code up into several small programs... The code for each of the command line options is written in a separate function...
> > everybody think?
Yep, I would like to have a program called puffinplc. But wouldn't having different names for the code (.c) and binary files cause confusion? What is the advantage of keeping them different?
Yes. I completely agree. But it might serve as an incentive to making them clean? I don't know... It's the first time I participate on a open sorce
project...
Are you thinking along the lines of
/libs for miscelaneous libraries
/plc for plc_lib.c and plc.h
/plc/smm for smm.h, smm_lib.c, ...
/plc/conffile for conffile.h, ...
/plc/log for log.h, ...
/plc/synch for future synch.h, ...
I would surely like the above structure. Do you have something else in mind?
Mario.
Mario J. R. de Sousa [email protected]
> > Jiri Baum:
> > > > > > to be run, plus setup and shutdown.
Mario de Sousa:
> > > to the smm-mgr but other stough has been coming in the way. The -g
> > > command line option would first init the common shared memory
> > > resources, and then launch modules configured in the config file.
Jiri Baum:
> > init(8)-style. Maybe that's just the small-pieces philosophy...
Mario de Sousa:
1) init(8) has some things that are specific to being process number one, invoked by the boot process, and being the only init running.
2) we'll probably want some special functionality eventually or even immediately - eg handling of the "quit" point.
Both, really.
The launcher actually runs throughout the lifetime of the PLC, handling both startup and shutdown, logging any modules that die etc.
To some extent I have this vague feeling whether the smm-mgr, having setup the smm, isn't in some funny state that we'll have to keep worrying about.
> > > everybody think?
> > process is separate, then smm-mgr keeps its name and the
Just that renaming existing files is a pain in CVS. Changing the binary name is just a couple of words in the Makefile.
> > > is that we move the utility function files (sin_util.c, sem_util.c,
> > > ...) to a common directory, so other modules may use them if
> > > required.
> > miscellaneous libs.
Nor do I... Probably depends on the individual file.
> > > keep the public interface to the smm directlory limited to the plc.h
> > > file.
I was thinking:
/lib/misc for miscelaneous libraries
/lib for plc_lib.c, plc.h and linuxplc.a (or puffinplc.a)
/smm for smm.h, smm_lib.c, ... (leave it where it is, or /lib/smm)
/lib/conffile for conffile.h, ...
/lib/log for log.h, ...
/lib/synch for future synch.h, ...
Obviously, there's no hurry for this.
Jiri
What we do Every Night! Take Over the World! Step 1 - bid for SMOFcon
Mario de Sousa
> I was thinking:
OK. I agree with the above, as long as its /lib/smm and not /smm.
I am doing a few misc changes to the code. Could you please wait untill I have committed them before you go ahead with the changes?
Thanks,
Mario.
M LinuxPLC Project 0
J LinuxPLC Project 0
M LinuxPLC Project 1
M LinuxPLC Project 3
