Dear All,
We have GE Mark V Cimplicity HMI which is connected via MODBUS TCP to DCS.
I tried to modify modbus.dat to add new signal into MODBUS. After editing modbus.dat then I did modbus_l in the command prompt F:\UNITn.
After that restart the TCI, including copy master config in workbench.
But the value of new signal still won't show up when I read using modbustcp simulator, while the old signal show up. At past time when we still use idos, it's so simple. just edit modbus.dat and do modbus_l and then the value will appear. So, are there any differences in config MODBUS list in Cimplicity with config in idos?
Thanks.
Regards.
Thanks.
Regards.
