configure SLC500 to communicate with micromotion MVD direct connect
Brian
Have an existing setup of multiple micromotion flow meters with directs connects that talk to SLC via prosoft modbus module.
Want to learn more about this setup in case I have to troubleshoot it or expand it. I have manuals for the various hardware components, but I haven't been able to put all of the pieces together.
Does anyone have some suggestions about key points or have some links to a setup guide or something with a high level overview?
Thanks in advance,
Brian
What SLC500 module are you using???
The 3150-MCM module has 2 DB-9 ports ont he front of the unit, while the MVI46-MCM module has 3 RJ45 units.
If you have the 3150-MCM, there is a tech note on our website describing "SLC Modbus Master/Slave to Endress+Hauser Promass"... This may not be the exact meter you are using, but should give you the right idea.
http://www.psft.com/training/PDFtraining.php
If you have an MVI46-MCM, I don't have a specific tech note for this, but if you would like to give us a call, we could answer whatever questions you have.
Thanks,
Erik
