Can Anyone give some ideas on how to Connect a Conductivity sensor to a PLC ?
R Thread Starter ROMAN Feb 8, 2004 #1 Can Anyone give some ideas on how to Connect a Conductivity sensor to a PLC ?
C chris Feb 9, 2004 #2 simply with an analog-input module, added to your PLC (via 4-20mA). or in a more sophisticated way by a bus-system (i.e. profibus dp), wich both devices has to be able to handle. good luck, chris
V vijay Feb 9, 2004 #3 sir, You have to connect that conductivity sensor to conductivity meter which will give 4-20/0-20 amps current regards vijay
D Dr. R. Erlich Mar 22, 2006 #4 Connecting Conductivity Sensor (cell) to PLC See application not number 48 @: http://www.eidusa.com/Interface_Boards_Application_48.htm Good luck, Ron
