P
I want to measure continuously varying water levels in a small rectangular steel tank (40mm x 200mm x 300mm deep, internal dimensions). I require resolution to +/-3mm. The tank acts as a stilling chamber, so the surface is smooth. 4-20mA analog output signal is required of the sensor. What continuous level sensing technology would you use?
