I have a signal processing system that has an analog voltage out anywhere between a range of 0-5 V. It is DC Volt output from a 16bit Delta-sigma Digital to analog converter.
I want to use this anlaog output vol to control an array of solenoid valves that control air flow.
I am sure I can do this using a PLC or a 18 pin microcontroller with input outputs?
Can suggest me what kinda solenoid valve can be used here. I must say the DV value is differnt at differnt instants. The reason is i am doing signal processing and based on a specific instant of signal processing i may get 2 , 3 or max 5 V DC voltage. It is not changing or alternating like AC.
I will appriciate any guidance on this issue.
I am an electrical engineer and working with mechanical engineers and biomedical engineers to control a robot.
