L
I have the following system to control:
electric shower that I have two inputs of water, one hot and one cold. I have two servo motors to control a flow valve for each entry. They then mix in a chamber with an electrical resistance that heats the water to the desired temperature. The goal is to control the flow and temperature output.
actuators:
- Servo-motors that control flow of each water intake;
- Electrical resistance that heats water;
sensors:
- Temperature and flow in the output of the system;
I need a mathematical model of the system and any idea how to control the plant. Can anyone help me?
thank you
actuators:
sensors:
thank you
