We want to automized our pressure system where we can set the amount of pressure inside our vessel from the gas tank. Let say we set pressure at 20 bars in the PC (via Labview software+data acquisition system). The PC then will trigger the valve to open and release gas into the vessel. Once the selected pressure amount is reached in the vessel (detected by the pressure sensor),the PC will trigger signal for the valve to close.
So what type of valve should i use? solenoid or control valve or other?
pls advise
pls advise
