P
what happens to the outlet pressure on a choke/control valve when the inlet pressure changes but the valve % open remains unchanged.
Presumably the flow rate decreases if the inlet pressure decreases and the flow rate increases if the inlet pressure increases. What happens to the outlet pressure does it remain fixed if the valve position is unchanged??
