E
<P>Hi Experts!
<P>We are studying the selection of a optimal control strategy in order to protect centrifugal pumps with the warranty of a minimal operation flow. The idea is to use a recirculation line with a control valve and openning the last as the flow measured (installed between the pump discharge and recirculation line) required. The problem with this solution is the minimal distances required to install the flow mearurement (10 to 20 line diameters following the API 550) and the final length for the recirculation line required.
<PRE>
-------<------FIC
-------VALVE------------------<---
->-----------PUMP--------FLOW-------------->
</PRE>
<P> If FLOW < minimal flow then open the VALVE to warranty minimal flow.
<BR> If FLOW >= minimal flow then close the VALVE.
<P>Could someone of you, please suggest other good or best alternative or simply justify our proposal?
In your experiences what kind of control schematic, what kind of flow measurement (primary element) and what kind of valve are using?
<P>Thanks a lot.</P>
<PRE>
-------<------FIC
</PRE>
